15 years agosimultaneous access to ddrII memory by nios and vhdl entity
Hi all, I am using Arria II device.Basicly,what i need to do is to transfer large amounts of bulk data,which is stored in DDR2 memory using Ethernet to PC.The problem is that vhdl-based entity is ...
15 years agoI have looked into UDX4 reference design.From what i see,the whole design is implemented inside the SOPC builder.Also,the vhdl entity needs to be instansciated inside the sopc builder.Let's say i did it.In nios II software , i know that i am able to access components with ease ,since the devices are memory mapped .How do i define the entity to be able to access the ddr II memory,for instance ( From definition point of view and also from vhdl code of view).Reference link/example would be welcome :)
Thank you.
