Simulating nios ii via modelsim - Launching stops at 57%
hello all,
I have created a simple project from nios ii SBT for eclipse, I runn it on the board it worked fine. But When I try to run it as simulation on modelsim it just stops launching at 57% .....
Any one has an idea what the cause might be?
- EricMunYew_C_Intel
Hi, Ameen
Do you have any logs ?
Eric
Hi, Ameen
Can you follow below to your run Nios II RTL simulation to verify your design.
Platform Designer will allow you to generate a testbench and a tcl file for simulation using ModelSim. Nios SBT will allow you to generate .mif files (your C code) for memory initialization.
You may refer to page 433 to 439 of below:
Eric
Hi, Ameen
Please kindly follow the document in my previous thread for Nios II RTL simulation (including your application code).
Can we close the case if you have no more question ?
Eric
