ABinO1
6 years agoSimulating nios ii via modelsim - Launching stops at 57%
hello all,
I have created a simple project from nios ii SBT for eclipse, I runn it on the board it worked fine. But When I try to run it as simulation on modelsim it just stops launching at 57% .....
EricMunYew_C_Intel
6 years agoHi, Ameen
Can you follow below to your run Nios II RTL simulation to verify your design.
Platform Designer will allow you to generate a testbench and a tcl file for simulation using ModelSim. Nios SBT will allow you to generate .mif files (your C code) for memory initialization.
You may refer to page 433 to 439 of below:
Eric
