21 years agoSimulating Nios II in ModelSim-Altera
Hi! I created a project in Quartus II, with a Nios II and some external logic. Well, the ModelSim can simulate the mpf file auto-generated by SOPC, but it contains only the Nios II... http...
21 years agoHello Matteo,
do you want to do a rtl or post-layout simulation? The last directory (which you use) is for post-layout simulation. Quartus writes the complete project (nios + custom hdl-files) into this directory. Because of the synthesis (built in into Quartus, or with a third party tool) the signal names can change. When you just want to make a pre-layout simulation you can use the second directory (std_1s40_sim) and change the project setup by writing your own setup-file. MfG Chris
