21 years agoSimulating Nios II in ModelSim-Altera
Hi! I created a project in Quartus II, with a Nios II and some external logic. Well, the ModelSim can simulate the mpf file auto-generated by SOPC, but it contains only the Nios II... http...
21 years agoThaks for your fast answer.
<div class='quotetop'>QUOTE </div> --- Quote Start --- Do you use the simulation directory from Quartus II or do you use your own simulation directory outside the Quartus tree?[/b] --- Quote End --- This is the directory in which I have my QPF QuartusII project file (standard.qpf): C:\altera\Progetti\ProvaCpu This is the directory auto-generated by SOPC for the ModelSim simulation in which I have my MPF file (std_1s40_sim.mpf): C:\altera\Progetti\ProvaCpu\std_1s40_sim This is the directory auto-generated by QuartusII in which Quartus has created the output file for ModelSim (standard.vo): C:\altera\Progetti\ProvaCpu\simulation\modelsim I defined my new ModelSim Project file (testbench.mpf) in this last directory, together with the other copied files (setup_sim.do, modelsim.tcl,ecc...). Of course, I have a little edited these files, but I don't know if correctly. <div class='quotetop'>QUOTE </div> --- Quote Start --- Do you get warnings when you compile the project in modelsim?[/b] --- Quote End --- No, I don't. It seems all ok, but I have the problems I desribed in the last post. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Bye!
