21 years agoSimulating Nios II in ModelSim-Altera
Hi! I created a project in Quartus II, with a Nios II and some external logic. Well, the ModelSim can simulate the mpf file auto-generated by SOPC, but it contains only the Nios II... http...
21 years agoHi Matteo,
Do you use the simulation directory from Quartus II or do you use your own simulation directory outside the Quartus tree? When you use a directory structure out of the Quartus directory you must also copy some files for the jtag_uart_log. There are also some path-definitions in the setup.do file which are needed to log uarts. When you use a normal uart in the project, the output will be also displayed in the modelsim window. Do you get warnings when you compile the project in modelsim? MfG Chris
