16 years agoSimulating Nios II in Active-HDL
Hi there, I am following an application note (APNOTE 768) from Aldec to simulate Nios II in Active-HDL using a standard design example from Altera. The apnote was written for the legacy tools N...
16 years agoI wonder which script generate the following response:
Post-processing to create RUN_ON_HDL_SIMULATOR_ONLY_ext_flash.flash elf2flash --input=RUN_ON_HDL_SIMULATOR_ONLY_s2.elf --flash= --boot="C:/altera/91/ip/altera/nios2_ip/altera_nios2/boot_loader_cfi.srec" --outfile=RUN_ON_HDL_SIMULATOR_ONLY_ext_flash.flash --sim_optimize=1 --base=0x0 --end=0xFFFFFF --reset=0x0 if [ ! -d C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ]; then mkdir C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ; fi Post-processing to create ext_flash.dat flash2dat --infile=RUN_ON_HDL_SIMULATOR_ONLY_ext_flash.flash --outfile=C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/ext_flash.dat --base=0x00000000 --end=0xFFFFFF --pad=0 --create-lanes=0 --width=8 --relocate-input=0x00000000 if [ ! -d C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ]; then mkdir C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ; fi Post-processing to create ext_ram.dat elf2dat --infile=RUN_ON_HDL_SIMULATOR_ONLY_s2.elf --outfile=C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/ext_ram.dat --base=0x02000000 --end=0x20FFFFF --pad=0 --create-lanes=1 --width=32 if [ ! -d C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ]; then mkdir C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ; fi Post-processing to create onchip_ram.dat elf2dat --infile=RUN_ON_HDL_SIMULATOR_ONLY_s2.elf --outfile=C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/onchip_ram.dat --base=0x02100000 --end=0x210FFFF --pad=0 --create-lanes=0 --width=32 if [ ! -d C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ]; then mkdir C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ; fi Post-processing to create sdram.dat elf2dat --infile=RUN_ON_HDL_SIMULATOR_ONLY_s2.elf --outfile=C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/sdram.dat --base=0x01000000 --end=0x1FFFFFF --pad=0 --create-lanes=0 --width=32 rm -f C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/contents_file_warning.txt if [ ! -d C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ]; then mkdir C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ; fi Post-processing to create ext_flash.sym nios2-elf-nm -n RUN_ON_HDL_SIMULATOR_ONLY_s2.elf > C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/ext_flash.sym if [ ! -d C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ]; then mkdir C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ; fi Post-processing to create ext_ram.sym nios2-elf-nm -n RUN_ON_HDL_SIMULATOR_ONLY_s2.elf > C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/ext_ram.sym if [ ! -d C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ]; then mkdir C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ; fi Post-processing to create onchip_ram.sym nios2-elf-nm -n RUN_ON_HDL_SIMULATOR_ONLY_s2.elf > C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/onchip_ram.sym if [ ! -d C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ]; then mkdir C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim ; fi Post-processing to create sdram.sym nios2-elf-nm -n RUN_ON_HDL_SIMULATOR_ONLY_s2.elf > C:/G3/test/Nios_Sim/s2/NiosII_stratixII_2s60_standard_sim/sdram.sym Post-processing to create onchip_ram.hex elf2hex RUN_ON_HDL_SIMULATOR_ONLY_s2.elf 0x02100000 0x210FFFF --width=32 C:/G3/test/Nios_Sim/s2/onchip_ram.hex --create-lanes=0
