16 years agoSimulating Nios II in Active-HDL
Hi there, I am following an application note (APNOTE 768) from Aldec to simulate Nios II in Active-HDL using a standard design example from Altera. The apnote was written for the legacy tools N...
16 years agoFor IDE tools, when I set it as "ModelSim only, no hardware support", it will generate lots of DAT and SYM files, which initializes the memory in simulation tools.
But for Eclipse, it generates ELF and MAP files instead. Does ModelSim support to read those files as input for simulation? Thanks, Hua
