16 years agoSimple Socket Tutorial Problem
Hello, I've been attempting to basically run through the Simple Socket Server template and tutorial. I've had previous problems attempting to use the hardware configurations from the examp...
16 years agoHi,
Open your SOPC system and check which is the component that locate in the address range. It is usually a memory component. Check the clock that drives this component. Study the documents of DE2 board. It could be due to clock skew problem for DE2 board.
