13 years agoSimple Socket Server Template can't find mac adress?
hello, I am using Simple Socket Server Template for my own triple speed ethernet qsys system in which I modify the NiosII Ethernet Standard Design by replacing DDRx with ssram on my CycloneIV ...
11 years ago --- Quote Start --- hello, I am using Simple Socket Server Template for my own triple speed ethernet qsys system in which I modify the NiosII Ethernet Standard Design by replacing DDRx with ssram on my CycloneIV GX150 Development Board.I just build my simple socket server project with the template(RGMII) without anything changed except for the tse_my_system.c.When I run my projec,the NiosII Console display some information as the text below: InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Can't read the MAC address from your board. We will assign you a MAC address. Please enter your 9-digit serial number. This is printed on a label under your Nios dev. board. The first 3 digits of the label are ASJ and the serial number follows this. -->Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) 123456789 123456789 Your Ethernet MAC address is 00:07:ed:ff:cd:15 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x0800a000 INFO : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED MARVELL : Mode changed to RGMII/Modified MII to Copper mode MARVELL : Enable RGMII Timing Control MARVELL : PHY reset INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link not yet established, restart auto-negotiation... INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.80 Acquired IP address via DHCP client for interface: et1 IP address : 192.168.1.104 Subnet Mask: 255.255.255.0 Gateway : 192.168.1.1 Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) :confused:What make me confused is how could i edit the source code to solve the problem of can't find mac address from my board.Could anybody give me some advice?I'm much obliged to you for helping me. --- Quote End --- hi,
i have the same problem but at the line above , "ip address of et1 : 192.168.1.80" , it gets stuck and becomes not responding. also it shows 0.0.0.0 in place of the ip address. any idea what can i do?
also do i need to manually enter the ip address, subnet, gateway etc in the following lines:
ip4_addr(*ipaddr, ipaddr0, ipaddr1, ipaddr2, ipaddr3); ip4_addr(*gw, gwaddr0, gwaddr1, gwaddr2, gwaddr3); ip4_addr(*netmask, mskaddr0, mskaddr1, mskaddr2, mskaddr3);
