13 years agoSimple Socket Server Template can't find mac adress?
hello, I am using Simple Socket Server Template for my own triple speed ethernet qsys system in which I modify the NiosII Ethernet Standard Design by replacing DDRx with ssram on my CycloneIV ...
13 years ago --- Quote Start --- AFAIK this is the correct flow of SSS; there isn't any error! It has stopped because it has indeed nothing else to do, until a connection on port 30 will be requested by a network client. --- Quote End --- I am sorry to disturb you again.I meet another problem when i using simple socket server.I use telnet to connect with my project.As the menu shows,When I press 0 then press retrun,I find that nothing happens with led.Could you help me to solve this problem?Because I don't know why.Thank you!
