13 years agoSimple Socket Server Template can't find mac adress?
hello, I am using Simple Socket Server Template for my own triple speed ethernet qsys system in which I modify the NiosII Ethernet Standard Design by replacing DDRx with ssram on my CycloneIV ...
13 years agocomment the entire code of "get_serial_number (void)" , if your board do ot have any serial number.
and then in generate_and_store_mac_addr() assign to ser_num = 1;//get_serial_number(); and then inside if loop assign your own XX value /* This says the image is safe */ flash_content[0] = 0xfe; flash_content[1] = 0x5a; flash_content[2] = 0x0; flash_content[3] = 0x0; /* This is the Altera Vendor ID */ flash_content[4] = 0x00; flash_content[5] = 0x07; flash_content[6] = 0xED; /* Reserverd Board identifier for erase boards */ flash_content[7] = 0xXX;//FF; flash_content[8] = 0xXX;//(ser_num & 0xff00) >> 8; flash_content[9] = 0xXX;//ser_num & 0xff; once again in function generate_mac_addr(unsigned char mac_addr[6]) assign one to ser_num = 1;//get_serial_number(); and assign /* Reserverd Board identifier */ mac_addr[3] = 0xXX;//FF; mac_addr[4] = 0xXX;//(ser_num & 0xff00) >> 8; mac_addr[5] = 0xXX;//ser_num & 0xff;
