16 years agosimple socket server problem
Hi i am trying to build the simple socket server example but i have got the following error when i doing this in nios2ide version 9.0 Severity and Description Path Resource Location ...
16 years agoThis is an odd problem. You've obviously got a uart in the system. alt_sys_init.c generated code in it to initialize the UART but it can't find a MACRO definition that it expects. Look in your "system.h" file to see if the macro "UART1_IRQ_INTERRUPT_CONTROLLER_ID" indeed does or does not exist.
Did you make changes to your system recently. Have you tried a "Clean Project" of both your project and system library before rebuilding? Jake
