12 years agoSimple Socket Server, No Response After Adding Logic
I realize that many questions have already been asked regarding the Simple Socket Server(RGMII). However, I cannot seem to locate a solution, mostly because I am unsure as to the problem. The S...
12 years agoAuto-negotiation passes, so I would think something is working. Also, There are no failing paths in that module, there are some in another partition that existed from before adding the ethernet system. However, I may not have fully constrained the design after adding the qsys system. On Monday I'll make sure that it is fully constrained and report back. Thank you for the reminder.
