12 years agoSimple Socket Server, No Response After Adding Logic
I realize that many questions have already been asked regarding the Simple Socket Server(RGMII). However, I cannot seem to locate a solution, mostly because I am unsure as to the problem. The S...
12 years ago --- Quote Start --- What do you mean with " moved the system into a larger project" Did you port the same system into a larger fpga device or did you import the SSS hw/sw into a different design? --- Quote End --- I moved the system hardware and software into a different design, on the same board. My QSYS system and its assosiated clock selection logic is in a different partition than the rest of my design which operates on a different clock ( They communicate through ports that have synchronizers + edge dectectors ).
