12 years agoSimple Socket Server, No Response After Adding Logic
I realize that many questions have already been asked regarding the Simple Socket Server(RGMII). However, I cannot seem to locate a solution, mostly because I am unsure as to the problem. The S...
12 years agoWhat do you mean with " moved the system into a larger project"
Did you port the same system into a larger fpga device or did you import the SSS hw/sw into a different design?
