19 years agosimple_socket_server hangs
The simple_socket_server hangs on our custom board. We can run the other RTOS templates, but the server hangs. It will print out the messages from micronium and then hang. The debugger show that it is running, but to us it seems that it hangs in netmain()->OS_sched(). Will this example hang if the LAN91C111 is improperly connected? /g1 Reply
And the answer is....no it will not.
But it will hang if something is wrong with the flash. The reason is the lack of error handling in the template code. /g
