17 years agosimple socket server example on cyclone II dev kit
Hi, I want to use the simple socket server example with the cyclone II dev kit. I compiled it and then I run it. In the file simple_socket_server.h I defined the IP-adress like this:
16 years agoHi, I am trying to use simple socket server example on cyclone II dev kit.
It seems to work BUT : when i send over 41 characters through ethernet (crossed câble) , dev kit goes to malfunction. I receive random characters and communication hangs. It is like there is too many characters. Too much work to do for Nios II + IP stack + microC/OS II. Have you faced to this problem ? Is there an example of Simple Socket server PLus (that enables FTP, TFTP, ...) for Cyclone II dev kit ? EDIT : --- Quote Start --- [SSS]: Attempted to post to a full message queue. --- Quote End ---
