17 years agosimple socket server example on cyclone II dev kit
Hi, I want to use the simple socket server example with the cyclone II dev kit. I compiled it and then I run it. In the file simple_socket_server.h I defined the IP-adress like this:
17 years agoAnd what was the console output in NIOS II IDE when you launched the application?
________ NIOS II IDE is very strange... Sometimes there is a build error and sometimes not. Also if I don't change the code.
