17 years agosimple socket server example on cyclone II dev kit
Hi, I want to use the simple socket server example with the cyclone II dev kit. I compiled it and then I run it. In the file simple_socket_server.h I defined the IP-adress like this:
17 years agoI connected the board with the "usb blaster cable" .
I used the example that uses triple speed ethernet. This example is included with the design kit but it's targetting cyclone ii family. However, you can use it I think. So, to answer to your second question (if I well understood): The output of the console was : " Reply from 137.57.123.58: bytes=32 time<1ms TTL=64 " .This show that the connection is established. Regards, Jeremy. Press enter to look up in Wiktionary or ctrl+enter to look up in Wikipedia
