17 years agosimple socket server example on cyclone II dev kit
Hi, I want to use the simple socket server example with the cyclone II dev kit. I compiled it and then I run it. In the file simple_socket_server.h I defined the IP-adress like this:
17 years agohi jjeerreemmyy,
did you connect your board directly to the pc? did you use a special cable? and what was the console output when you launch the application?
