16 years agoSimple socket server example build error
Hardware consistes of CPU, SDRAM, LAN91C111, TIMER, UART_JTAG, PIO(8 bit for LED), PIO(16 bit for seven_seg)
Software is the example from kits. When built without modifing, errores were occurred, it read make[clean]:error 127 (ignored), and make:***[alt_error_handler.o] error 2 So I had to check which files encoutered problems ,found that unresolved inclusion showing.# include <alt_iniche_dev.h># include "ipport.h"# include "tcpport.h"# include "libport.h"# include "osport.h" So how to deal with them? Thanks for any suggestions.1 Reply
- Prajwal_RJ146
I'm also facing the same issue,
did you found any solutions?
thanks and regards
Prajwal RJ
