13 years ago"Simple Socket Server" demo code stop after display "simple socket server starting up
Dear Friend's i am using DE2_115 board and over that i am running simple socket server example, i just strip out LED and 7-Seg Show Task's from my Code and compile it but when i run this peace ...
13 years agoYou must write 1 to the edge capture bit in order to clear irq.
Then the correct command in irq handler should be: IOWR_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_BASE, 1); Probably the problem is simply here: irq is not cleared, thus keeps on retriggering and your code gets stuck.
