16 years agosimple socket server connection established, but cannot ping/telnet
hello guys,
I got a problem with simple socket server problem. I post similiar thread in dev kit forum, but no answer until now. I am thinking maybe I could get help from here. Thank you in advance. My situation is here: hardware: cIII 120 develop board software: QII 9.1 sp2, Nios II 9.1 sp2 What i have done: 1. copy the C:\altera\91\nios2eds\examples\verilog\niosII_cycl oneIII_3c120\triple_speed_ethernet_design to my project fold and open with QII 2. open sopc builder and run generate 3. back to QII and compile to generate sof (time limited version) 4. open nios eclipse ide, create a new project with simple socket server template 5. to avoid troulbe, modife get_mac_addr() as: ****************************************** int get_mac_addr(NET net, unsigned char mac_addr[6]) { mac_addr[0]=0xB7; mac_addr[1]=0xA7; mac_addr[2]=0xED; mac_addr[3]=0xFF; mac_addr[4]=0xFF; mac_addr[5]=0xFF; return 0; // return (get_board_mac_addr(mac_addr)); } ****************************************** 6. I disable DHCP in wizard and I use cross cable to connect board and PC directly. 7. run app as "Nios II hardware" what I got: =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack" ================================================== === InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Static IP Address is 192.168.1.234 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x08004000 INFO : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=1, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.234 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) Everything looks smooth, but I cannot ping, telnet or whatever else. When I ping, the RX light is flashing, but TX light not.43 Replies
looking for best soliution?
Pay attention that in the reference design the CPU Data & Instruction masters are both connected both to the flash and to the SDRAM.
I saw design failing 'cause porting the design to a new version or a new board, those connections were not properly done. To also exclude HW issue on your specific board (if not the PHY), you can map all into an On-chip memory RAM if you've enough free. I also report here from previous page: - if you've limited time SOF you shall keep the USB Blaster connected and do not close the pop up that comes once you program the device. - be sure to have given right timing constraints to your RGMII IF and that your timing are closed. - Altera_Forum
I solved my similar problem by killing the virus.^_^
