16 years agosimple socket server connection established, but cannot ping/telnet
hello guys, I got a problem with simple socket server problem. I post similiar thread in dev kit forum, but no answer until now. I am thinking maybe I could get help from here. Thank you in ad...
10 years agoPay attention that in the reference design the CPU Data & Instruction masters are both connected both to the flash and to the SDRAM.
I saw design failing 'cause porting the design to a new version or a new board, those connections were not properly done. To also exclude HW issue on your specific board (if not the PHY), you can map all into an On-chip memory RAM if you've enough free. I also report here from previous page: - if you've limited time SOF you shall keep the USB Blaster connected and do not close the pop up that comes once you program the device. - be sure to have given right timing constraints to your RGMII IF and that your timing are closed.
