20 years ago
simple project with DMA
I've been working a long time with NIOS II Stratix edition.
I want to improve my system's performance by adding DMA. My problem is, that everything is working well. However if only add DMA to my system, even a simple printf instruction doesn't print on the screen hrough jtag.
As a target I want to copy data from custom peripheral to SDRAM memory. However at this time I just want my project to work with DMA instantiated.
If you have suggestions, please write. Or could give me a link to a simple project which uses DMA. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
    Most (if not all) "Full Feature"ed designs have Avalon DMAs. There is nothing special about adding a DMA. It&#39;s just another Avalon master.
    I would double check your SOPC Builder design to make sure that your processor is still connected, correctly. Additionally, I would step through all of the code in alt_sys_init() to determine what (if anything) is failing to initialize.
    Cheers,
    - slacker
    --- Quote Start ---
    originally posted by slacker@Jun 19 2006, 12:19 PM
    most (if not all) "full feature"ed designs have avalon dmas. there is nothing special about adding a dma. it&#39;s just another avalon master.
    i would double check your sopc builder design to make sure that your processor is still connected, correctly. additionally, i would step through all of the code in alt_sys_init() to determine what (if anything) is failing to initialize.
    cheers,
    - slacker
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16253)
    --- quote end ---
    --- Quote End ---
    there is examples in the nios2 software development handbook
    Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Thank you for the advices
    I verified the cpu connections, alt_sys_init and I looked to the handbook. All of the devices are instantiated and initialized in the alt_sys_init (as those in full_featured system from design example from nios2 kit), the cpu is configured as before adding dma so it should be fine.
    HOWEVER it&#39;s NOT http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
    Do you know any other reason?
