12 years agoSimple interfacing between Avalon MM Slave and ARM HPS
Hi all, I'm trying to create a simple example of a master-slave communication between the onboard HPS (running Linux) and the FPGA fabric using a Cyclone V. The method I've followed so far is ...
9 years agoHey,
1) Please check if you included the Avalon slave in the Qsys component. 2) Check if you have exported the port "scratch_slave_32_bits_rw_0_conduit_end_export" as Conduit in the Avalon slave Qsys component. You could use this well explained blog for reference: https://zhehaomao.com/project/2014/01/02/fpga-series.html Regards, Akshay
