12 years agoSimple interfacing between Avalon MM Slave and ARM HPS
Hi all, I'm trying to create a simple example of a master-slave communication between the onboard HPS (running Linux) and the FPGA fabric using a Cyclone V. The method I've followed so far is ...
9 years agoHello Akshay, Im using your code to test. But I have an error. {Port "scratch_slave_32_bits_rw_0_conduit_end_export" does not exist in macrofunction "soc_system_inst_1"}. Do you have any idea ? Thank you.
