21 years agosimple examples not work,give me idea
Hi ,everyone
examples within nios2 5.0 can't work(ep2s60f ,stratix2 high speed broad) , I load .sof successfully(ex. full_featured in niosII_stratixII_2s60_ES), follow, I create a application base on hello_world, check runas ->hardware , "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused" What's means ?3 Replies
Is your program running from flash memory? In that case 'run as hardware' doesn't work, you should download your program with the flashprogrammer. best regards, Dolphin - Altera_Forum
Most likely a hardware issue (rare for those words to come from my mouth http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ). Debug your hardware I/O (make sure the unused I/O setting in Quartus is set appropriately for your board (Nios boards need 'set unused I/O to input tristate'), make sure you assigned the I/O properly, make sure you meet timing, etc....)
Thank you!
