11 years agosignaltap: can't fit blocks
hi, everyone. i bulid a project that contains nios and signaltap analyzer. my device, max10M08SAE, has 387,072bits on chip memory, in the qsys, the on-chip memory is 20480 bytes(163,840 bits), ...
11 years agoIf you want a detailed view of your resource count you should open up the compilation report (button next to the programming button in quartus)
Then go to Fitter > Resource Section > RAM summary It will tell you what is using up memory bits and how many M9K blocks it requires.
