11 years agosignaltap: can't fit blocks
hi, everyone. i bulid a project that contains nios and signaltap analyzer. my device, max10M08SAE, has 387,072bits on chip memory, in the qsys, the on-chip memory is 20480 bytes(163,840 bits), ...
11 years agoTaz is correct. Your memory is partitioned into several M_K or MLAB blocks (42 in your case). Partially filled up memory blocks still count as a used partition. When you set up signal tap make sure you don't exceed your maximum memory block count (it updates as soon as you place your signals).
