11 years agosignaltap: can't fit blocks
hi, everyone. i bulid a project that contains nios and signaltap analyzer. my device, max10M08SAE, has 387,072bits on chip memory, in the qsys, the on-chip memory is 20480 bytes(163,840 bits), ...
11 years agoPlease have a look at the fitter report, but be aware that the implementation bits are not the used bits.
Let's give you an example: your device has 3 M10K Blocks, so 30.000 Bits available and you have one instance, let's say a FIFO which needs 21.000 Bits of them, then there should be 9K Bits left, but you can not split a M10K into pieces, so all three Blocks are full. That also happens if you have two fifos with 128-Bit, then 2 M10K Blocks should be used...
