20 years agoSignal Tap
I have some problems with the Signal Tap Logic Analyzer. Sometimes it works pretty nice and I can observe the selected signals. But sometimes it smashes my design completely, if only I change some nodes. Means: I run the design on the board, using the signal tap logic analyzer, have no problems at all. Then I decide to observe some other signals, change the nodes in the signal tap setup window, recompile , and my design behaves completely strange. I get no warnings (beside the 1400 standard warnings :-/ ) or errors during compilation. I'm using Quartus II Version 6 and a niosII Cyclone II Development Board I hope, that somebody can give me a hint, because its very annoying to compile 1 hour for nothing...1 Reply
Hi Maria
First, I'm sorry for my bad english... - What happens, if you re-change the nodes back to the state before? Very IMPORTANT: - Are you shure that your design is really synchronous? Some severe asynch path in your design will sometimes produce exactly this situation: every time you re-compile your design (without any change !) the result is not predictable. This is not an failure of Quartus. Your design in FPGA must be as synchronously as possible. I had that problem while re-engineering an completely asynch APPLE II into synch FPGA. Now I have more grayed hair after finishing that project succesfully... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif Jens
