20 years agoShould I confing my net setting?
HI all:
I use "ifattach --addr 172.18.1.29" config my net setting in alter 1c20 broad. But fail. Who can help me?What cmd shoule I use? Thank a lot!2 Replies
alex824,
You didn't specify your mask or net settings. In your file system project under etc dirctory, open your rc file, uncomment the line used to manually assign your ip address and update the settings to match your network settings. Of course you can try this from your terminal window before commiting these changes to flash. Doug - Altera_Forum
--- Quote Start --- originally posted by dcurry@Nov 7 2005, 07:31 AM alex824,you didn't specify your mask or net settings. in your file system project under etc dirctory, open your rc file, uncomment the line used to manually assign your ip address and update the settings to match your network settings. of course you can try this from your terminal window before commiting these changes to flash.
doug
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10821)
--- quote end ---
--- Quote End --- Thank you very much,I will try it.
