20 years agosharing uart by two processor cores
Hi all, can two nios II processors share one uart terminal i am using NDB stratix II device. i have connected two nios processors to one uart. also i have attached one mutex in sopc builder....
20 years ago --- Quote Start --- originally posted by nobodii@Oct 19 2005, 05:20 AM did you try to have two nios2-terminal connect? you might have conflict at the nios2-terminal because of the single com port that is connected, but not the nios ii because the sopc builder will take care of the switching between multiple master to a single slave.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10446)
--- quote end ---
--- Quote End --- Hi niosdii, what is this "Did you try to have two nios2-terminal connect? You might have conflict at the nios2-terminal" i could not understand what is that nios2-terminal connection!!!! exactly i am getting the same problem. also now one more thing.even if i try to have only one processor and only one connection to uart even then it is saying permission denied for accessing the uart as stdin/stdout/stderr.even single processor is unable to get uart control finally now. i am unable to get the things clearly.can u please help me in this thanks and regards prasad
