20 years agosharing uart by two processor cores
Hi all, can two nios II processors share one uart terminal i am using NDB stratix II device. i have connected two nios processors to one uart. also i have attached one mutex in sopc builder....
20 years ago --- Quote Start --- originally posted by prasad_forums@Oct 14 2005, 10:24 PM i have connected two nios processors to one uart.
but when i run(mutually exclusive) in each processor
it is saying can't open the uart permission denied. --- Quote End --- Usually, connecting two processors to the same peripheral is a bad thing, since they can get into a fight. However, it is theoretically possible, if you use a mutex, and write your own device driver. If you're using the HAL drivers, I'm pretty sure it won't work; you'll have to give each CPU its own UART.
