20 years agoSharing data and address between SDRAM and Flash
Hello, Due to some limitation in the amount of IO pins SDRAM and Flash have to share the same address and data bus. Are there any differences between connecting the Flash to a separate tri-stat...
20 years agoHello slacker,
Thank you for that information. Recapitulating when data and address bus is shared between SDRAM and other tri-state devices the connection of the SDRAM signals doesn’t change (A0 of the SDRAM must be connected with A0 of the external bus) and A0 of the external bus must be used for the other devices on the bus for byte addressing. When the hardware is ready to start I will post the results here. Regards, niosIIuser
