20 years agoSharing data and address between SDRAM and Flash
Hello, Due to some limitation in the amount of IO pins SDRAM and Flash have to share the same address and data bus. Are there any differences between connecting the Flash to a separate tri-stat...
20 years agoI think you should add a tri-state bridge to connect Flash device to Nios Flash componet. And tri-state's A0 is map to byte access.
