12 years agoShare variables between verilog file and niosII application file(.c file)
Hello, I am trying to do a small concept where in I have created a project on DE2-115 board. In the same project, I have also implemented niosII processor and written a simple program to toggle th...
12 years agoSorry, I have one doubt over here,
Implementing MM slave will allow me to share maximum 16 regs of HDL. What if i want to fill 10Mbytes of SDRAM location in HDL and later on use it in NiosII application? Will the MM slave still be the answer to this. I doubt this because in MM slave i found only 16 regs were available. In my application, I want to fill the video data (Around 10Mbytes) in SDRAM using HDL and later on retrieve the Data from SDRAM in niosII application for sending it to external world. -Jagdish
