12 years agoShare variables between verilog file and niosII application file(.c file)
Hello, I am trying to do a small concept where in I have created a project on DE2-115 board. In the same project, I have also implemented niosII processor and written a simple program to toggle th...
12 years agomy apologies for replying this late.
before trying the template wanted to get some clarity. Is the above template applicable even while using On-chip memory? OR Is it that on-chip memory can be handled in much simpler way and directly using hdl and niosII? One more question where are the variables stored that are declared in hdl. (integer, reg). can't this variable's memory location be accessed using niosII. thanks -Jagdish
