12 years agoShare variables between verilog file and niosII application file(.c file)
Hello, I am trying to do a small concept where in I have created a project on DE2-115 board. In the same project, I have also implemented niosII processor and written a simple program to toggle th...
12 years agoThe template implements far more than you need. For example it defines 16 registers (= shared variables) whereas you only need one; moreover it manages different data access modes, variable data width and many other features.
If you don't bother keeping all this stuff in your code, you can integrate it straight in your code. Otherwise cut away the non essential bells and whistles.
