12 years agoSGDMA Transfers only 20 bytes
Hi, I am having an issue using the SGDMA core with a NIOS core and uCOSII. I think the code sets up the descriptor correctly (this to tx a packet out the TSE MAC): the source is the transmit b...
12 years agoI think the standard Nios II designs that Altera provides with their kits does have cache. You can check it in SOPC Builder / QSys, Nios CPU parameters, in the Memory interfaces tab.
From what you are describing, it looks like a synchronization or cache problem, and I'd say the latter is the most likely.
