12 years agoSGDMA Transfers only 20 bytes
Hi, I am having an issue using the SGDMA core with a NIOS core and uCOSII. I think the code sets up the descriptor correctly (this to tx a packet out the TSE MAC): the source is the transmit b...
12 years agoSo if I understand you correctly, the packet size is correct, but the end of the data isn't correct. It could be either because your software begins to overwrite the data before the DMA is finished sending it, or it could be a data cache coherency problem. If your CPU has a data cache, ensure you flush the data buffer before you start the SGDMA.
Are you using Altera's driver with the Interniche stack, or your own implementation?
