13 years agoSGDMA status return code 'C'
Hi, I'm trying to perform a simple SGDMA transaction. Memory to Memory. The data is transferred. I use IORD on both memories and read the data to check. But the status code retu...
13 years agoThat's not one of the error codes enumerated in errno.h, but it's the value from the sgdma status register: bits 2 and 3 are set and this tells you the dma transfer has correctly completed. See page 23-13 of the sgdma controller datasheet for thorough status register information.
