14 years agoSGDMA debug
I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<- (http://www.codeupload.com/4051) (I've edited the code found on forum, so thanks the guy who provided it). In order to check what is written to the memory, I've connected the SGDMA modules to ONCHIP memory (size: 32768 bytes) and enabled memory content reader on the on-chip memory options. You can see my connections ->here<- (http://i51.tinypic.com/1zz6fj5.png). The problem is that this dma design doesn't work. The data I get is corrupted. I've tried to disconnect cpu.instruction_master and cpu.data_master from onchip memory, then the memory start address goes to 0x00, but results are the same. If I connect the DMA to the DDR memory, then the data passes correctly, Screenshot is ->here<- (http://i53.tinypic.com/2heak61.png). Now why I get this situation: either I try to read or write from/to onchip memory or DDR memory, the core always tries to read/write from/to address 0x800xxxxx. Obviously when it is connected to DDR ram it works, but when to onchip ram it doesn't. Why is this happening? Nios memory bus bugs? How can I check what is written to the memory? If I use only onchip memory for the whole system and DMA it also works fine, but I want a clear vision without Nios stuff in the memory. Thanks.
