12 years agoSFP link/speed detection - NicheStack
Hi, I am using NiosII + ucOSii + NicheStack in a webserver application. Instead of a regular MDIO-accessible PHY device I am using a SFP cage compatible with any standard SFP module (i2c access...
12 years agoSkimming altera_avalon_tse.c, it's not immediately obvious how to exactly accomplish it, but it looks like you want to declare your own instance of 'alt_tse_system_phy' with your own 'tse_phy_cfg' function, and register that via alt_tse_system_add_sys().
Search altera_avalon_tse.c for that printf "MDIO not enabled! Speed = " and you'll find the if() else() clause where the existing software would have liked to run your user-supplied function tse_phy_cfg(). Good luck.
