20 years agoS/F core
Dear everyone, My nos2 is 50Mhz, S -core, has been tested, all is ok! when I change to 50M/F-core, select the instruction cache and data cache, the "netflash" command is not ok...
19 years ago1. Is your board a custom board, or a dev board ?
2. how do you call netflash ? which device? 3. do you use cfi core ? what is your flash chip? 4. you must always use uncached address to access flash, never mix with cached.
