20 years agoS/F core
Dear everyone, My nos2 is 50Mhz, S -core, has been tested, all is ok! when I change to 50M/F-core, select the instruction cache and data cache, the "netflash" command is not ok...
20 years ago --- Quote Start --- originally posted by smalllight@Oct 19 2006, 02:00 PM tank you for you replies.
i have readed the ioremap.c
the __ioremap's code as follow:
__ioremap() in file arch/nios2nommu/mm/ioremap.c
* map some physical address range into the kernel address space.
void *__ioremap(unsigned long physaddr, unsigned long size, int cacheflag)
return (void *)(physaddr);
hippo can you tell me why you change the code to "return (void *)(physaddr|0x80000000); "?
i will regard your comment ,thank you
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18786)
--- quote end ---
--- Quote End --- Smcnutt had noted ioremap() in this thread, http://forum.niosforum.com/forum/index.php...=735&hl=ioremap (http://forum.niosforum.com/forum/index.php?showtopic=735&hl=ioremap) Next, look at the cfi flash map driver, linux-2.6.x/drivers/mtd/maps/altera.c nt __init init_alteramap(void) { static const char *rom_probe_types[] = {"cfi_probe", "jedec_probe", 0 }; const char **type; ndk_amd_map.virt = (unsigned long *)ioremap_nocache(WINDOW_ADDR, WINDOW_SIZE); Look at the ioremap() and ioremap_nocache() in linux-2.6.x/include/asm-nios2nommu/io.h they all want the return be uncached address. Though the mtd map use the uncached functions (from io.h) to access memory, linux-2.6.x/include/linux/mtd/map.h Actually, the original code did not do anything about uncache. I could agree with that, if all the access are consistent. ie, always use the uncached functions (from io.h) to access memory, and never mix access with the cached virt address .
