20 years agoS/F core
Dear everyone, My nos2 is 50Mhz, S -core, has been tested, all is ok! when I change to 50M/F-core, select the instruction cache and data cache, the "netflash" command is not ok...
20 years agoI think it is a bug of Nios2 kernel. (Scott noted it in 2004.)
Please update, __ioremap() in file arch/nios2nommu/mm/ioremap.c /* * Map some physical address range into the kernel address space. */ void *__ioremap(unsigned long physaddr, unsigned long size, int cacheflag) { return (void *)(physaddr | 0x80000000); // uncached }
