21 years agoseveral questions about making my target board
I use mk command to generate a target board project. I open this project ,and open sopc from tools menu in quartus, but I found this system has included cpu_0, firmware_ROM, data_RAM, payload_B...
21 years agoI misunderstand you. Do you means : is it necessary to add new Nios when you create new nios system after creating "target board"?
Yes, obviously, you should add new Nios and Jtag, and some other components to implement what your thinking. The "new system " project and "target board" project" are in diffrent usage. The "target board" project only using when you use "Flash programming" to programming "new system" project ( the "target board" project will programming to FPGA first to programming "new system" project to Flash, then after power reset, the "new system" project will work.)
